AR2 woofer stopped working
My Ar2ax's are the later version and have six mounting holes with the t nuts. First I tried the foam gasket tape from Parts Express when reinstalling the woofers. Worked great on large Advents, but was a no go on the AR's. Wound up using three lines of rope caulk from Ace Hardware and it worked fine.
Ugh...too bad about that woofer.
These last three posts are good, and I hope I can clarify matters a bit. The AR-2 series (AR-2, 2a, 2x, and 2ax) did indeed use three different woofers, and the obvious physical variables were: outside basket diameter, number of screw holes, surround material, cone material, and magnet type/shape. This may be far from complete, but chronologically:
Type 1: cast metal basket (11" dia), 6 screws, cloth, heavy ribbed cone, cylindrical alnico magnet. Found in all AR-2 and 2a's, and in 'early' 2x and 2ax.
Type 2: pressed metal basket (11" dia), 6 screws, foam, smooth paper cone, slug alnico magnet. Found in 'transitional' 2x and 2ax.
Type 3: pressed metal basket (10" dia), 4 screws, foam, smooth paper cone, slug alnico magnet. Found in 'late' 2x and 2ax.
Am not 100% positive about a 'late' 2x, but nonetheless, the transitional woofer (like larrybody in post 21) was meant for cabinets with the larger diameter baffle cut-out as AR began shifting towards foam surrounds. While types 1 and 2 should both perform well and fit the AR-2 cabinet, if your other speaker is the original cloth woofer, that is what you will want for your second speaker as well.
I don't know what makes these drivers go dead, but before I tossed that beloved 10" woofer in the trash, I might want to first chat with Bill Legall at Millersound to see if a repair might be possible. Many serious east coast audio geeks say that he is the man for repairing the unrepairable.
http://www.millersound.net/about.htm
Great info ra.ra! From what I've seen on fleabay, the 2&2a woofers look the same, hence my comment.
Now, why would a woofer be short circuited? Even if the VC is scraped badly there should be some non-shorted turns between the terminals - unless the VC has multiple layers (unusual) and the short is between two very close turns. Take a real close look at the tinsels to see if there is some short between them or between them and the metal basket. If so, the fix is not necessarily a replacement.
Alrighty! Picked up a "new" woofer of the bay. Unfortunately there was a tear in the paper cone, so I carefully fixed that with some glue and coffee filter. BUT, now both AR-2s are singing pretty!
Thanks everyone for their input and help!
