David Brehm
Hi speaker experts,
I am trying to restore some 1969 AR3a's. I have followed the guidance from the speaker restoration pages, re-capped the speakers, and gotten the spider's on the woofer's repaired by Larry at vintage-ar.
I replaced the pots with some new ones from hifiaudio on ebay:
AR-3 AR-3a AR-2 AR-2ax AR-4 AR-4x AR-5 AR-6 wirewound potentiometer pot
But I'm still stuck. My issue is that I am occasionally getting distortion from the midrange drivers.
I took the midrange pot out, wired it again, and got it working. Then put it back and it started distorting again. I have wiggled every connection and cannot reproduce the distortion at will.
Did I make a mistake on the wiring? Is it the proximity of the two pots next to each other that is causing this? Is it something else?
How can I troubleshoot this? I have a second set of speakers with an A/B switch so I can go back and forth. I have test equipment, the REW EQ software on my mac and a mic to measure distortion.
I have attached a picture of the wiring. Any help would be gladly appreciated....
David Brehm
David Brehm
