EDIT: THIS IS THE PART ARC SELLS
Well I thought this one was working 100% but…the common issue got me.
The right channel doesn’t come in until you turn the volume to 1/3 or more. Then it gets way louder past 1/2!
I’ve tried DeOxit.
Do I just have to pay up to Audio Research or what have others done?
CLEARANCE ALPS 100KAX2 100K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
ALPS 100KAX2 100K Ohm Audio Taper Stereo Potentiometer 6mm ShaftThe Alps 100KAX2 is a 100K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long, with M8 thru-hole mounting, hardware included. The body of the potentiometer is 1.073" W x 0.97" H x 0.93" D (27 x...
www.parts-express.com
I’ve tried DeOxit.
