ARC SP-3 Volume Control Issue
Yeah, I would be disappointed with that too. For $125, they should sell something with the right shaft length and doesn't require modifications to the chassis. (Even if it's a traditional pot vs. a stepped attenuator.)
I hope it works out. [Btw, that's a nice looking unit. Heck of a lot cleaner inside than the one I have.]
It’s playing now. Can’t use the same connection scheme as the old control or max and min will be flipped. Gotta switch the out and grounds.
They charged me $80 for a part that’s literally still in the bag from Parts Express for $15.
Did you make measurements to see if anything else would fit? Alpha makes a couple styles of dual 500K log pots, sold by AES for less than $5. I have had zero problems with their products, but maybe the shafts aren't long enough for this application.
That’s scummy business.
Not to mention the part doesn’t even fit!!!
The stub out on the control to hold it has no where to go, and the shaft is too long.
Okay, then I take it back. ;-)
Let me look at that site. But moot point now I guess. I really thought ARC’s part would be drop and go.
The two SKUs at AES are R-V38-2XXA and R-VA2XXA. There are links to data sheets with drawings that show exact dimensions of the bodies, bushings and shafts. I use these when I'm building gear that uses pots.
Yeah threading isn’t long enough on either.
On the original:
Thread: 11mm
Shaft past threading: 9mm
Shaft diameter: 6mm
Threading diameter: 9mm
These are all approx. as I don’t have a caliper.
I've been looking into replacing the volume pot on my sp3a with the Alps pot. Someone replaced the original with a stepped pot that has a terrible clunky feel to it, and the wiring been messed with.Do you have a picture of the Alps pot wiring you could post for me? I'd appreciate it!
I do not, but you have the schematic and all volume controls are wired the same (one wiper side to ground, wiper signal out) and you know the pinout of the Alps pot.
The replacement ALPS pots available from ARC or aftermarket ( careful of fakes) don't have the correct bushing size for the ARC openings of the SP3.
You can drill out the sub chassis or you can grind down the perimeter of the bushing on the pot itself to fit. You'll also have to cut the shaft without destroying the mechanisim of the pot itself.
If you want a pot that fits off the shelf and his FAR higher quality than the ALPs and sounds like it there's this one:
Fits exactly through the opening of the chassis and the faceplate and no cutting of the shaft. However, if you were concerned about the price from ARC then you may not of been interested in this superior option. From my point of view , ARC are dealing with a small subset of enthusiasts for 45 year old pre amp and actually have a solution for it- they have to answer the phone, heat the place and hold stock of an obscure part-- the price is not that bad. Ask CJ for help and see what your options are.
We are dealing with EOL equipment as far as the manufacturer is concerned. ARC actually did not have a balance control replacement for the SP 3 ( they do have the tone controls!) so I had to deal with making one work on my unit. You can see the TKD pot in this thread as well as my solution for the balance control.
Hope your repair went well.
