Hello, I made some post earlier in this thread. Experimented a bit with indoor Dipole antennas home-made and purchased. Partly brick facade here.
But I got best results in a totally impossible corner behind a brick wall some 2-3m in (from outer wall measured). Even better than hanging the dipole by the window or outside even. Crazy.
Got 14 channels, 6-7 were very good to excellent, the others 50-60% signal level and mostly noise free.
Since then I made some radical changes. Purchased a Nedis omni FM-antenna. Took down the TV-antenna that was on the mast before and put this up instead. Not interested in the Swedish ground network anyway.
I have tried with the old cable that was from the previous owner of the house, to the tv antenna etc. And with a never used cable with pressed on f-connector. And the old cable is best (however I did redo the connector since the shield braid was not much connected properly at all).
Anyway, the results are completely sick, once I hit the sweet spot with turning the antenna.
There is more, but I have only tuned in the ones with good noise free quality, so I left out the ones with 30-40% signal level and some static in the background.
I now pick up 31 stations, some ca 20 of these are with excellent signal level 70 - 100% and instant rds decoding on the ones that transmit that data. Perfect quality.
The others are around 60-70% with instant rds decoding (same as above) and perfect crystal clear stereo.
Of the 31 are now also 7 Danish channels! I live in Sweden, in the north eastern part of Skåne (southest part of Sweden).
5 of these are from Sjaelland and 2 from Bornholm (Rø station) which is some 140km away from me, these 2 are coming in the strongest of the Danish with steady 80% signal level, crystal clear of course.
The signals from this transmitter travels a long way over the water before they come in over Sweden. The other 5 of the Danish, some are steady but lower signal around 50-60% but noise free and perfect rds and stereo etc. But some may come and go depending on weather conditions.
I find the results simply mindblowing and I like listening to radio, so I am very happy now
I will now put the cable in its proper place, so I will lose some 2-3 meters of it, which may further improve signal to noise ratio, giving those low signal stations that are barely within reach, an extra push.
The antenna cost around eqv of 23 usd on amazon
Then it was some cable channels and connectors etc for some other eqv 25-30 usd
So a cheap upgrade that added a huge amount of value. Can totally recommend.
Sorry for long post, but wanted to give details.
Some pics also.
The antenna. I have the coolest antenna in the neighbourhood now
No one of the neighbours has an antenna like this.
One of the Danish channels from Bornholm (some 140km away) coming in super strong and crystal clear
The other Bornholm station coming in with a blazing full signal
I'll be sure to give this antenna the best review.
