Are these Polk Monitor 7's safe to put next to my Xbox?
A strong magnetic field can erase a hard drive. But, if everything is OK so far, you're probably in the clear.
Curious though, can the 360 be stood up beside the One? That might be a bit safer, if you're still worried.
You should be fine. It's a passive radiator closest to the Xbox anyway. Not exactly a flux capacitor. Then you'd be in real trouble.
