I kind of like the fashion of the Sonneteer. Form following function = good design. Actually, that's one of the prettiest preamps I've seen. So simple, balanced and clean!
It's an integrated amp and it's in my living room as I type.
Anything that basic has to sound good. That's all it has to do..it certainly isn't there as needless bling.
I don't think its just a fashion statement, as that would imply that most of the people I admire as designers/engineers did it for fashionable reasons. Stan Klyne didn't put anything trendy in my preamp...its just a black box with some of the best build quality I have seen in anything. Nelson Pass? Fashion statement?
I really don't believe that Nelson Pass couldn't design tone controls into a preamp that would work well and disappear sonically when not in use/switched out. I think the lack of tone controls has become a hair shirt audio fashion statement, which means that builders of high end gear don't have to bother with them. Kinda like no one being able to put an auto lift on a high end turntable.
The guys at Luxman did a great job with the tone controls on the 550 AX. There if you need them. Not noticeable if you don't.
Tilt is a subtle, well, "tilt" of the frequency response towards either the treble or bass. Imagine a hinge in the middle of the straight response, and like a teeter totter, it leans very slightly one way or another.
BTW, I forgot to mention what was in the system I was hearing the Luxman with. The turntable was the big Avid Acutus Reference, with the monster power supply. Cartridge was the new Transfiguration Proteus. Speakers were Wilson Benesh Discoveries. Simply amazing sounding.
We also played with a Nagra BPS phone stage, which bettered the phono stage in the Luxman, but also cost half of the Luxmans price. Not that the Luxman phono sounded bad. The Nagra just sounded quicker and more detailed, compared to the more luxurious sounding Luxman.
Actually, I think a more flexible implementation of this is a very good idea - stepped attenuation with fixed value resistors or a transformer behind a quality switch - sure you add a switch to the circuit but only a single resistor (or transformer lead) behind it instead of a pot.
I originally built my 2A3 amp with a good ALPs pot in a shunt configuration for attenuation (in case I needed it) but when I bypassed the whole thing with a simple quality resistor, it sounded better.
Again, less seemed to be more.
What a wonderful system. That had to be fun!
