bluenote79
Member
I think the TD-160 is better regarded than the TD-165. But others can add their comments.
One thing is you should be on a concrete slab with these TT's unless you use a wall shelf. I had a TD-160 and it didn't work with a suspended floor (i.e. crawlspace under floor) due to bouncing as I walked. It'll work fine with a wall shelf, which is what I was using. On a concrete slab, no problem at all.
I honestly don't know much about these tables at all, except that folks around here seem to favor vintage Thorens over a lot of stuff that's on the market today. But, what I don't understand is why these models (with apparently good suspension) would need any special treatment in placement (within reason). Lots of members originally recommended the Technics sl 1200 because of the quartz locked speed and because of it's solid build, but when you mentioned that your TD 160 picked up movement as you walked, that makes me wonder.
