JohnMac
Addicted Member
Thanks for that.
Ok, after several applications of acetone over a two hour period I still couldn't break the screw loose. So, I used a Dremmel with a cutting disc and cut the pesky pin out in place. That made a big difference. The arm pivots very freely now. The brass barrel and the housing move together as though they were one.
Next question. I removed the platter and there is what is left if some kind of bearing washer on the boss that the platter sits on. It is black and somewhat sticky. Obviously this needs to be cleaned off but I don't know what to replace it with. Nylon, brass? What is left of the original looks like some kind of rubber or foam that has descintegrated.
I haven't gotten as far as inspecting the motor yet but wonder if it can/should be lubed.
