bar72
Hi all. So I decided to move from solid state to a valve amp. I record a lot of vinyl to computer so I can save on wear and tear but have noticed that my waveforms are off centre. Waveform looks like it's leaning to positive polarity on left channel and negative on right.
Checked for ground loop in my system and if I check waveform in Izotope, there is zero DC Offset present so I'm assuming it's the phono preamp / Valves [EH 6922's].
I've read elswhere this can be caused by Valve Overdrive but I have no idea what this means. Can anyone help with this?
I have ordered a pair of PC88-Tesla's as they have a 7 volt heater as I also read that some amps can run at an excess of 6.3 volt, causing premature failure? Just unsure if this is what is meant by valve overdrive?
Any help, thanks in advance.
Code:
https://www.watfordvalves.com/product_detail.asp?id=1144
