Today just received the AU-20000 that purchased 6 weeks ago. When opened up the carton, was very sad & disappointed to see the speaker selector switch & the left side "handle" were broken, both dropped into pieces inside the carton. The chassis & both side covers were bent. The only good thing is all PCB are still in tact, no cracks / broken. The carton was so thin and lack of protective foams & cushions. The seller basically did not consider the weight of this unit when doing the packing, really feel very bad...At last managed to flatten the chassis & side covers, whole units seems quite OK. Here need some help...
1). Where is the voltage selector switch located ? or how to set the voltage input to 230V (just cannot find the switch...)
2). Where can buy the speaker selector switch ?
Thanks in advance
Regards
Thanks in advance
Regards
