pete_mac
Thanks to the skills of skippy124 (my father) I've now got a nice recapped/cleaned/deoxit'd AU-517 which is about to take over the main duties in my system. It will be replacing a AU-417 so whilst the general cosmetics are almost identical, the AU-517 is much beefier overall.
We used a mix of caps due to certain stuff not being readily available in Australia - a mix of Panasonc FC and FM, some Panasonic audio caps, and some Nichicon where I couldn't source Panasonics.
Prior to cleaning the amp (still dusty) with the driver boards removed:
The dreaded glue (before and after). Dad fashioned an EXCELLENT glue removal tool using a long strip of PCB material, with one end sharpened into a chisel-like implement. It made short work of removing the glue. As you can see, the glue had corroded some components:
Finito! Apart from some very minor scratches on the top edge of the front fascia, the amp is in WONDERFUL condition. DC offset is set to pretty much 0mV, bias is 20mV (was 20mV offset and about 60mV bias before adjustment).
Best of all, she sounds great! After a few hours of testing on small speakers to verify proper operation, I will open her up on some big'uns. Can't wait!
Thanks again Dad. :thmbsp:
