AU-D907 LIMITED vs 919
I think I am right in saying that the 'AU-D907 Limited' is regarded as the JDM model of the 'AU-919', and judging from a quick scan of the specs of the AU-D907 Limited, there is minimal difference.
As the model says, the AU-D907 Limited is based on the AU-D907 (JDM model of the AU-919).
Most obvious differences are the copperplated chassis and the woodpanel cover.
Inside there are more differences, bronze baseplate for the power supply (transformers and main filter capacitors). Further there are some "upgrades" in components, outputs and driver transistors are the same as in the AU-X1!
Then the output coupling capacitors (polar back to back config) from the head-amp and flat-amp are special Nichicon Gold low noise instead of the Nippon.
According to @Bumpalump there are also some small differences in the pre- amp boards.
From the four I have two don't have the "black flag" styrene capacitors but the noble styrene what for sure is nice.
I don't know if they used them more often in the Limited but for me it's 50 %.
(In the picture you can see the styrene capacitors in the back of the flat-amp, the Nichicon LN coupling capacitor, the bronze baseplate and copperplated chassis)
Yes, once watched the thread of bumpalump on a repair of the AU-D907 Limited. Didn't even know it existed but for sure wanted one.
That's how I started my JDM adventure, still knowing really little about this D 07 series. I reckoned because they are a Limited edition (according to Ishinolab they made and sold around 3000 pc) I'll get some more to save them ;).
I had to pause my restoration work for the time being because of personal issues but hope to be back at it at the end of the summer. Will have to finish my AU-D907 (almost done) and the AU-D907G Extra ( still some work pending on the repair being good) but after that the Limited.
AU-D707 (AU-819) uses NMA/NMC1216, AU-D907 (AU-919) uses NMA/NMC1012, AU-D907 Limited and AU-X1 use 2SC2493N/2SA1068N.
I do think the NMC/NMA are probably the same transistors, just different current and/or voltage specification.
The 2SC2493/2SA1068 could be just the next iteration of the then new multi- (ring-emitter) power transistors with high fT ( 30+MHz).
The NM refers to the non magnetic casing.
Once read somewhere that the NMC/NMA were developed in a collaboration between Sanken and Sansui. I guess as an answer to the NEC 2SC2337/2SA1007 high fT (70 MHz!) used by Trio/Kenwood in '77/78 in the LM07/09 power amplifiers.
Don't know if there is any truth in that.
AU-D707 (AU-819) uses NMA/NMC1216, AU-D907 (AU-919) uses NMA/NMC1012, AU-D907 Limited and AU-X1 use 2SC2393N/2SA1068N.
The 2SC2393/2SA1068 could be just the next iteration of the then new multi- (ring-emitter) power transistors with high fT ( 30+MHz).
So they are interchangeable with equal performance?
Providing the Output Transistors are the correct specification the amplifier will sound great. The output transistors contribute but are far from being the only thing that makes this happen - the overall design leveraging the advantages of such transistors is key.
As far as I know the NMA/NMC transistors were specially made for Sansui, several HiFi manufacturers did this, maybe as a way of protecting the 'intellectual property' of their designs. But it does mean the exact specifications of such transistors was never generally released, and only some inkling of their spec's was gained from how they were used. And maybe also from electronic testing of undamaged examples removed from amplifiers, and possibly microscopic physical examination of the transistor chips themselves. :dunno:
Hyperion, You told me to use this also and I replaced them at the same time that I replaced the outputs too. The sound improved!
https://www.digikey.com/en/products...mAaEA9lANogCsIAugL7X4KSkCyAUgKJhkAMAzGAOJVqQA
The link you give here is for MJ15031G, which is physically similar to the original (driver) transistors, but is not actually a good substitute for use in an AU-919. Consequently I didn't recommend this one, I mentioned its physical similarity, but instead pointed you at KSA1220 and KSC2690.
Here is a quote of my post from the thread link in your post #16 above.
You really don't have a lot of choice unless you can find NOS originals, the substitutes suggested, although overkill in respect of their basic specs, have the important metal tabs, (TO220 case) which is the same arrangement as the originals. There are other replacements with similar spec's like KSA1220A (PNP) & KSC2690A (NPN) - but they don't have the metal tab (TO126 case) - so your installation of these types needs to take account of this.
And why? because the Ft of the MJE's isn't good enough in the same way that influences the choice of Output Transistors.
Since that time the readily available and very suitable TTA004B and TTC004B have appeared on the scene, but these still don't have the metal tab.
And that's why I got me the Sanyo 2SA1105/2SC2580 transistors that have the same fT and the metal collector tab.
But ...
I have to say, reading about the impressions of people that use the onsemi MJE's the difference is may be not that big at least not on the overall sound.
More on this topic.
The NEC 2SB537/2SD382 do not have an extremely high fT, the Toshiba 2SC2238/2SA968 (used in the AU-X1, D907 Limited ) are higher in fT.
Some data sheets.
NEC: 40-45 MHz fT
MJE15028/29/30/31:
Low is specified at 30 MHz fT but in the graphic you can see that at 500 mA ( I would guess around the max a driver transistor in an AU-919 will have to deliver) it's around 60-80 MHz fT.
Of course I do not have this graphic of the NEC 2SB537/2SD382 but feels like comparable.
Now for final comparison the Toshiba
Typical 100 MHz but in the graphic you can see that it starts dropping after 500-600 mA. And at 1 A the fT is lower then the Onsemi!
Make your own conclusions!;)
And to make it complete, I found the fT curve of the 2SB536/2SD381.
Take in account there are different voltages used 5V and 10V, Onsemi unspecified! And I don't know how to interpret that.
Already on the way down from 40 MHz at 200 mA.
