You forgot the hockey pucks![]()
That was one of the best mods, and cheap you can do. I am the guy from you tube that turned you on to this link. I have my arm off my table and am ready to fix the anti-skate today. I will update you here on results. If I have to change the spring, I will have to dremel some of the plastic away from right above it. Looks doable. Between you and Vince, I am taking both of your ideas on my project. I probably should have just sold the table and bought a better one but now it became a I gotta make it the best it can be project. Who knows, I may be impressed with the results.I went out and bought 8 o-rings and put them on the tone arm. It added about 1 gram of weight so I had to break out the digital scale for a reset (I have the oversized counterweight). Did one recording afterwards and sounded nice! The size to look for is 3/8" inner diameter. Be sure to unclip the tone arm before putting them on as it requires a little oomph to get them over the headshell connector. Made a list of mods to do, but will take some time as I have to buy a few things at a time. Also have to make sure I get the correct things and also that I'm sure I can do them. Hate to tear it apart and not get it back to together?!
VinceiThat is doable. I liked the addition I did of RCA jacks on the back, that helped. Damping it is always good, the sound coat works very well. I am not sure what you want to do with the shielded wire, would you run that just from the base of the tonearm to the RCA jacks?
I thought I read you adjusted the bearings in the tone arm, can I ask you if you remember, how you did it?Great job! Glad it worked out and with a few upgrades, can be made quite enjoyable.
I used a homemade spanner screwdriver to loosen the outer locking screw and then and a jewelers screwdriver to carefully adjust the the bearing screw so the bearings have no play, but no binding either, a very careful balance! YouTube may have some tutorials for the SL-1200MK2, which is the same principal. Just be very careful, you don't want to make things worst. If in doubt, leave it as is unless it's really loose.I thought I read you adjusted the bearings in the tone arm, can I ask you if you remember, how you did it?
Thanks in advance
Glenn
I ordered and received 4 sheets of Sound coat the other day. Waiting to strategically apply it for the sound dampening, but waiting on a new tone arm wiring harness I'm going to order next week. Found one from AudioQuest (Wildcat https://www.amazon.com/AudioQuest-W...9819&sr=8-1&keywords=audioquest+tonearm+cable) at Amazon for $89 to replace from the Din with 4 feet of cable to the RCA and ground terminal. Was going to buy wiring and a DIN and make a soldering project out of it, but my soldering gun is big and bulky. Having carpal tunnel with arthritis would make it a very difficult project to complete. I recently posted on my YT channel Reasons Not To Buy An AT-LP120 USB Turntable that I've gotten quite a few views and comments (). I will update and post a new video on YT showing my last mods with results. Just wished I had a sample of before I started this journey of when I first bought this TT.
