Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
My current cartridge on my Dual 1219 is an Audio Technica ATN 95e. Is the Audio Technica AT VM 95 en (moving magnet)considered an upgrade? Also, will it work with the Dual 1219 factory headshell? Thanks!
If you have the AT95 cart, ATN is a stylus number, then yes the EN is an upgrade as it is a nude elliptical; regular E is bonded. One thing to note, the VM95 styli fit the AT95 body so you could just replace the stylus on your existing AT95 with a VM95 stylus of your choice rather than the whole cart. ML is very nice.
Yes, the EN would be an upgrade. The 'nude' stylus is mounted directly to the cantilever, so the sound will be faster, and more detailed. I would recommend a nude elliptical in almost every case over a bonded.
The ML stylus is a good one, as well, but a good nude elliptical can be all that's needed for some people and systems.
