more or less. I don't remember if I ever measured the output power of mine but 8 watts is probably about right. With efficient speakers thats actually enough. Don't feel too bad though, they cheated me on my TA-600 as well. Fisher claims 40 watts, it does 18 per channel or 9 per channel with both driven.
yeah I never made any follow ups. Got too involved in rebuilding it and just never turned the camera on. It takes a lot longer to do things on video than it does to just do them.
usually its just bad grease. The parts get sticky and none of it moves properly. Cleaning it out and replacing with fresh does the trick most of the time. Alcohol or mineral spirits will get the old crap off. I use silicone grease, white lithium is also fine. Basically any relatively light grease that won't melt out or get stiff is what you need. The motor and platter bearing want some sewing machine oil or something similar to that. The trip mechanism under the platter just has to be clean and dry, same with the inside of the platter, the motor spindle, and the idler wheel surface. A wipe with rubbing alcohol will take care of it. If you grab a service manual for the AT6 or AT60 it will show you which parts should have what.
