The for sale ad resurfaced and I gotta Yamaboner. Anybody know the physical size parameters of C118 & C119? I'm on the verge.
B-2X jones
B-2X jones
B-2X jones
,50mm dia x 50mm LI read some good threads from ya on the B-2X and saw the video. Good stuff. Question about the unique 100mF, 6.3V fat caps. I found 3 or 4 at digikey between 3 and 4 inches tall. Happen to have any physical size info or some old ones laying around for reference?
Thanks
B41456B4100M000 | DigiKey Electronics
Order today, ships today. B41456B4100M000 – 100000 µF 16 V Aluminum Electrolytic Capacitors Radial, Can - Screw Terminals 10mOhm @ 100Hz 12000 Hrs @ 85°C from EPCOS - TDK Electronics. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
EDIT: Sorry for silly questions & such. I noticed your thread where 2 members sent you those caps for testing and was curious if the old caps are still around. I wouldn't use old ones per say. Just curious about lead spacing and such. Thanks
Much appreciated Rott. The 80mm height are best I can find at the moment. Any spare room in the transformer area for jumper redneck ops?50mm dia x 50mm L
C118 and 119 on the amplifier assemblies. 100,000µf/6.3vdc These need to be almost the exact same dimensions as the OEM parts or smaller in both dia. and length.
***** Good Luck *****
These might be available in Japan. But I wouldn't hold my breath.
Sparky... Got any 50mmx50mm caps in Japan for this? Need 4. Please check under every bowl of rice cuz I'm kinda worked up over this piece.Sorry about your leg Scape, those rogue waves can be a birch.
If I didn’t already have a B-2, I’d definitely get a B-2x (might still do some day), it has a more detailed sound than M-80, to my ears anyway. Beside, it’s heavier by 3Kg so it must be better … you know how it is.
Also, I’m not aware of any particularly difficult to find parts that went into B-2x that would make them so hard to repair. Someone could/should confirm. B-2x does, however, have speaker terminals that are overly susceptible to damage. I have seen too many with broken/lose/missing/damaged speaker posts/assembly. Oh, and B-2x is a class A amp which means hotter than your usual all class AB amps.
Good luck whichever you get and get well soon.
are the ones in your unit bad?Sparky... Got any 50mmx50mm caps in Japan for this? Need 4. Please check under every bowl of rice cuz I'm kinda worked up over this piece.
Thanks
Esoteric redneck with blueballs
I haven't asked the seller about that cuz they usually don't know their ass from a fuse. They might be good for all I know. I just wanna swap them from age for longevity. If they're unobtaniums, I might walk away with blue balls.are the ones in your unit bad?
LOL … will look around but don’t hold your breath, capacitor variety for consumers in Japan is very limited. I often get my special caps from Mouser, go figure.Sparky... Got any 50mmx50mm caps in Japan for this?
