B&k people out there
thirsty93
Just a bunch of Nht stuff
I'm curious I use a B&k 125.2 and a 125.7 both are signature 2 amps between the two amps what is the difference.Same size chassis but one is 2 ch and one is 7 ch.does the 7 ch have smaller caps power supply ect?
B&Ks are not that common so it may take a bit for someone to have the info you seek.I have a B&K 507 avr.
I think that people need to know what you're after. If you need multi-channel, you need multi-channel. I think the consensus is the the older amp are better.
The reason I’m asking is when I had the tweeter and mid wired into the seven ch they were a bit bright and when I wired them into the two ch it went away
