Oldsansui441
Hi, l have recently purchased these beovox 4703's. Two woofers weren't working when l got them, one had an open voice coil and the other had a bad solder at one voice coil to flexible lead wire junction.
I bought four more original woofers but 3 of the 4 turned up with jammed voice coils (shifted magnets). I have repaired 3 woofers so far, thinking of doing them all so l don't have to worry and so l have fully functional spares as well.
I also recapped the crossovers, replaced resistors and replaced the woofer wiring. If it helps anyone the shims used for centering the magnets are 0.94mm and shims for centering voice coil are 0.14mm.
I have them all back together and they do sound very nice indeed, l have found mids to be slightly more pronounced than the lows and highs, have my amp loudness on to compensate for this, don't know if this is normal for these.
I do have 3 questions:
-The yellow cabinet insulation (packing) is still in the plastic bags, is this normal? It kind of seems to defeat the purpose with the plastic.
-The large crossover caps that l have pictured are supposed to be 75uF, all four measured between 125uF and 157uF, surely they weren't marked "incorrectly" from Wicon factory? I have replaced many caps in amps and receivers and have seen some old caps higher in value than specified, but never double esp on a high value like this?
-I will have to re-veneer the cabinets as they are unfortunately rough, should l go with golden teak as original or perhaps American oak. I know they came out in oak and l can get this much cheaper. https://www.veneersonline.co.uk/col...eer-sheet-unglued-fleece-backed-3500mm-x300mm
Or this teak
http://www.ebay.com.au/itm/112197259361?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Or this walnut
http://www.parts-express.com/band-it-walnut-veneer-24-x-96-paper-backed--260-048
Some guidance on the veneering would be much appreciated as l haven't attempted before, should l be using iron on or would the fleece or paper backed be ok to use with a spray contact adhesive?
I appreciate any feedback. Here are some photos of my progress.
Or this teak
Or this walnut
