No. The problem in the amp I was working was spurious noise being produced by a noisy transistor in the buffer amp. Which would of course show on the meter. It doesn't have to be audible noise. Not saying that this is necessarily the problem in your case, but in that case it was. Just an idea for a place to look. You'll have to apply your skills to narrow it down. It could be a noisy transistor in the meter drive, or the buffer, or in the amp itself. It could be a cracked resistor or cracked solder joint. There are a lot of things it could be.Dear ,...do you mean you replaced a transistor on the meter amplifier board ?...
I always take for granted that they check for a stuck meter.meter drive is AC coupled going into the last transistor - so pegged meter is most likely shorted last transistor or mechanical issue (meter stuck) Look for DC going into meter.
Noisy could be any one of the transistors or ICs (As @tarior pointed out).
Means the IC or transistors died.the vu-meter is not blocked...
the defect appears only when the power is turned on,
if I disconnect the input cable the defect remains,
I'll check the voltages on the board this evening.
Yup. It does sound like a chip or transistor shorted out then.Means the IC or transistors died.
Perfect. It's now narrowed down to the meter drive circuit.the vu-meter is not blocked...
