How to fabricate TO-3P transistors to fit into TO-3 sockets.
Here I have the 2 gold pins, a ring terminal, insulating bush, M3 washer, TO-3P Mica washer, Transistor, M3 16mm, & M3 20mm Stainless Steel screws.
Cut the E & B legs off the transistor (as shown) and shorten the C leg, use a small file to lightly round off the square ends of the E & B legs - for neatness when soldering.
Two gold pins shown, (left=uncut, right=cut) Cut the solder buckets off the gold pins, use flush cutters (as shown) just leaving the insertion stop disk at the top of the pin. Use a small file to lightly smooth the top of the pin where it was cut.
NB: Use safety glasses when cutting the pins, as the cut end of the gold pins really fly off when cut and could injure you.
Here is the cleaned heatsink, the sockets (underneath) have been removed, cleaned and then put back.
Insert the two gold pins into one of the sockets and tin the ends (as shown), the pins should be inserted just enough to grip in the socket. Cut a ~3mm strip off the bottom of the TO-3P mica washer so it doesn't interfere with the E & B legs, and position it as shown.
Position the transistor, insert the 20mm screw with washer, then tighten down the screw carefully making sure to keep the gold pins directly underneath the E & B tabs. When the screw is tight make sure the transistor and mica washer are positioned correctly, and also the gold pins - then solder the E & B tabs to the gold pins - leave a little blob of solder on the top of each tab to show that the new gold pin leg has been soldered and for neatness.
Now add the bush, and the ring terminal, slide the terminal onto the C leg and trim the leg as needed. Insert the M3 16mm screw, and tighten it up. Then solder the C leg to the terminal after making sure everything is lined up neatly.
This is one transistor complete, note that I have not added any heatsink compound yet as I think it advisable to complete all this work without getting the compound everywhere. I will complete all 4 transistors on this heatsink before removing them all and applying compound to complete the job.
Part numbers:-
Gold pins = TE Connectivity 1650155-1, Farnell P/No 2310222
Ring terminal = Molex 0.5-1.0mm M2.5, Farnell P/No 2295580 (I drilled it out to M3
TO-3P insulating set (x10) = Multicomp MK3305, Farnell P/No 520238
I hope this is helpful.
