Excellent work John. Thanks for sharing your method for the modern transistor install.
Side view of modified transistor. Top left the ceramic insulator can be seen.
and all 4 mounted on heat sink.
I have a question regarding C17 & C21 on the driver PCB - should they be 1000pF (Polystyrene) as per the schematic (and parts list) or 1500pF - a clumsy replacement (on the track side) by the previous owner of this BA-F1 ?
I am rounding up the very last additions to a parts order, so confirmation of this would be really helpful.
Edit Update
I'm leaning seriously towards 1000pF on this one.
If those 1000pF capacitors aren't there, I think that was a mistake by someone, and they should be installed. I assume there are positions for them on your PCB? - if so, use those positions. (You could mount them on the underside, but I recommend the topside).but am sure these were not present on my driver boards. Now my obvious concern is if it would be wise to install them as per schematics - what will be the pros and cons? An d if so, should I mount them to the underside of the PCB, or better over R37?
Thanks John for your quick response and your keen observation! You are absolutely correct - the capacitors are present on the PCB already. My mistake, I should have looked better; guess I was preoccupied by the picture showing some sort of polyester capacitor, where these are polystyrene foil I think?...
Just to be clear.
I just had a close look at your picture in the post above - and those capacitors are present on your PCB - the added 1500pF capacitors that I mentioned were in the unit I restored should not be there and were removed.
Not particularly, but one channel of the one I did was a bit of a 'dogs breakfast' of repairs - so I simply mirrored the resistor changes in the previously blown channel to match the good channel. The replacement resistors fitted to the damaged channel were too big, different types, and were badly fitted so I got rid of them.Are these prone to failure that you know?
F-2965/2966
Anyway, very happy with your reply.
While we are at it: it appears R37 was replaced; R38 looks original (green arrows) - this channel showed quite a few old repairs. Are these prone to failure that you know?
Following suggestions in other threads, I will replace the NFB resistors by high quality/low thermal drift metal films next upgrade pass. Thinking about upgrading all resistors in the signal path as well.
Any other candidates for upgrades suggested?
Hard to say - depends on pre-amp used for the BA.Which one is superior in SQ,
BA is better.build
BA is easier.repair ease
I think people will always consider the BA to be higher in value. The AU-D11 II gets a lot of flak for its build quality, and its SQ seems to get disregarded, and then there is the different electronic design which can be a problem for some.and value.
I can't remember any specific differences, sorry.Emphasis on SQ plz.
Well, bench testing complete, listening to it now for the first time, being driven by my C-2102 pre-amp (- fully reconditioned) - it's beautiful, plenty of bass with a very nicely presented image. Female vocals are very nice, and rock music makes you feel like turning it up!
This thread is awesome, thank you to all who contribute to this. I am very lucky to own a CA-F1 and BA-F1 combo and they are quite the kit. While in excellent shape, the CA-F1 has some distortion in the mids and highs, so it’s shelved for now until I can get some time, and the BA-F1 has some crackling in the right channel for about a minute on warm up, but plays nicely. I also own a 717 and am a huge fan of Sansui, so thanks again for sharing all this knowledge!
I have been entrusted with a really nice BA-F1 to restore for an AK member, I collected it last night. It is in at least a 9/10 condition overall, and appears un-molested inside apart from a replacement set of OnSemi output transistors for one channel. He is not expecting it to be finished until early next year - so I have plenty of time to make a really good job of the restore.
The restore
I'll probably post some before and after PCB pictures if there is interest, as this model doesn't seem that well documented / illustrated here on AK.
Any tips?
For those of you that have already tackled one of these I would be very interested in any tips you may have picked up regarding this model. I am also interested to know if anyone knows the whereabouts of a guaranteed one channel set of OP transistors going spare anywhere, the originals in the other channel are NMC1012 // NMA1012. (The OnSemi replacements used are MJ15024 // MJ15025 which are fine really - but maybe originals are better).
Pre-amp?
The owner really wants to get a pre-amp for it, I have suggested he does everything he can to get the CA-F1 - the perfect pairing.![]()
