Arkay
Lunatic Member
Over time and in the process of upgrading gear, I've gradually acquired a system which has both balanced and unbalanced connections built into every piece of gear (except a few sources like some TTs and cassette decks), and most of them are fully internally balanced. I've tried connections both ways, and concluded the following, at least in my situation:
(1) IF your entire chain offers balanced circuitry and connections, then go balanced XLR all the way. I can, for example, put a CD in a Denon or Pioneer player with balanced out (I have both), or a cassette into a NAK so equipped (my ZX-9 qualifies) into a Counterpoint line stage with balanced in/outs, to a pair of Counterpoint amps or Yamaha amps with balanced in/outs. Doing this entire chain with good-quality balanced cables (either various DIY or Mogami/Neutrik) results in the best overall sound, despite the theoretical introduction of additional balancing components to the circuitry.
I'm not sure why this is, but it may be that other gear in the environment, such as computers, a wireless router, and a plasma screen TV, are contributing low-level noise that the balanced connections help keep out of what I'm hearing. Or it may be the connectors themselves, as RCA connectors are inherently poor, obsolete technology that we are only stuck with for historical reasons. For whatever reason, going all balanced XLR sounds best in my system. But NOTE that this system has 100 percent balanced connectors throughout the chain. YMMV, especially if you are trying to mix-and-match connection types.
(2) As soon as you introduce an unbalanced connection into the chain, things can change. For example, if I'm playing records from the GT-2000, which does not have balanced connections, I have to be careful not to put my computer too close to it. The unbalanced cables, despite internal shielding, can pick up some of the noise. Perhaps that is also reflective of the very low-level signal going through them. Or maybe it's the cartridge or something else picking it up; all I know is that I need to keep the computer separated from the TT area.
(3) Even with balanced cables, the exact cables you use can affect the sound. (Yes, cables can and do make a difference, at least sometimes). I made several sets of cables using different types of microphone and coaxial cables and different connectors (Neutriks and some Japanese ones). I was lucky to pick up a bunch of different quality cables from a government surplus place, including some from actual studio applications, which gave me the luxury of being able to do this at low cost. Although the differences were more subtle than most, there were clearly reproducible differences between them.
(4) As much as possible, stick with ONE type of interconnect cable throughout. That is, match left and right channels AND match the cables used between source and pre and between pre and power amps. Mixing and matching different types of cables almost always has a negative effect on the sound. My suspicion is that each cable subtracts a different area of the sound, and additive subtractions (a nice oxymoron, huh?!
) result in loss of overall sound quality. Of course, any difference between the right and left sides will have a negative impact on the sound stage, too. Find which type of cable best suits your ears, and use it throughout. {Possible exception: when gear used in different stages has seriously different impedance matching issues, and you are using cables to help adjust for that.}
