Not sure,- how far to take this.
Should I do a full re-cap when the unit is able to function after some minimal strategically placed component changes.
As originally mentioned, I am not sure if this signal is internally created or simply HF noise (now virtually non existant, down to about 4mv).
The flat amp active devices have a bandwidth up to 100MHZ, so does the Power amp and the original Power Amp Finals bandwidth to 50 & 70MHZ respectively.
When the early production units began suffering from oscillation problems, the designers had to go back and make corrections. They probably didn’t want to reduce the effective bandwidth too significantly because it could negate the original intention of the AU-X1 model. So from looking at the apparent factory mods and deviations from the original schematics, I believe they determined that a few small changes strategically placed could provide small incremental reductions of HF noise passing that overall could significantly reduce the possibility of oscillation, yet probably did not totally eliminate the HF noise signal. The noise/oscillations signal I have seen in this unit may simply be the remnants of this HF signal that the designers tried to reduce, and it may have always been there.
I was able to employ a slight additional HF band pass reduction to help assure that this unit will not suffer from the oscillation issue. I could keep going but when is enough, enough? It might never be able to be completely eliminated. Then again if I did completely eliminate it, how would that effect the sound? Some might say that the bandwidth is so high that what difference would it make, but I believe this is what makes the AU-X1 what it is and I hesitate to change it all. I just wanted to be sure that it will not self-destruct. And it is now working flawlessly after several weeks of testing every day.
I guess that only time will tell. I could be singing the blues later - then you can say "T o l d - y o u - s o" - but for now it is a pleasure to have it as near to the original design as possible.
Thanks
