hmm...here's my thinking, please correct me if I am wrong. The impedance (resistance) is double w the 16 v 8 ohm speaker, so all other things being equal, the 8 ohm speaker should be 3 dB louder. However, since sensitivity ultimately determines max SPL, the 3 dB difference between the two seems relatively unimportant.
When I review the sales catalogs of the various manufactures, they offer16 ohm versions of many different compression drivers and 15" woofer models. People must buy them. Why? What is the advantage?
I have two pair of large main front speakers: EV's @ 16 ohm, and Altec's @ 8 ohm. Both pair are fairly sensitive at about 98, but that number is not precise. When I A/B test the speakers on my system, the volume difference at a given amp volume setting is negligible. Of corse they have different tonal qualities, but volume difference is minor.
I have never used any speaker at less than 6 ohm. Have always avoided 4 ohm due to the current load they present.
My next project will be two way speakers; 15" woofers w compression/horn driver. My current amplifier power is more than needed (110 -150) but I plan to select high sensitivity components, any suggestions?
