I did a LOT of online research into spindle oil a few month back when I was trying to address the speed instability of my Rega Planar 2 (turns out it has a slightly eccentric sub-platter). I found that by far, most people in the Rega community anyway (including Rega) recommend 80 weight hypoid gear oil. With the synthetic variety suggested for longer life.One tech told me he uses synthetic ATF (automatic transmission fluid) as it has what he considers to be appropriate viscosity (at the rpm a TT runs at, of course) and won't drain off. Just another thought.
I used 80w gear oil for a while, but last time I had it apart, ended up using Tri-Flo which seems to work well also.
80 weight gear oil is very heavy; almost like soft caramel. Tri-Flo is lighter, but still thicker than sewing machine oil, which I understand is best for finer moving perts but too thin for main bearings.Man thats a high viscosity isn't it? I bought some of that once for a bicycle hub. I thought we were to stay with lower weight oils like sewing machine oils or something similar. Interesting because I have a fair amount of it at home.
Here's a question for the recent posters to this thread...
Thorens TD 124 and also TD 121... how many drops of oil do you put in them? It can't be too much.
In a general sense..do you want the oil to be (with the platter mounted) 25% up the vertical shaft, 50% up the shaft, all the way to the top? (let it ooze out so it's 100% full after platter is inserted)
I've always just used just a couple three drops in the well on all the Thorens I have, just enough to cover the well bearing. Plus I use a Q-tip to apply a thin film of oil on the bearing shaft before placing the platter back in the well. That way the walls of the well, the shaft and the bearing itself are lubricated from the get go.
Using motor oil from the end of a dip stick is about the stupidest thing I have ever heard. Do you have any idea how close the tolerance is on a TT bearing. Now lets throw some metal shavings from you cars oil in there. Think before giving piss poor advice like that !
And yes I will spend MY money however I choose.
The problem with motor oil .
