Does it straighten out while it is playing?
Good question
The stylus is centered but has a slight angle while tracking.
The specs say 20' tracking angle
Which is about what I am seeing
S
Technical data
Output voltage at 1000 Hz, 5cm/sec. 3,3 mV
Channel balance at 1 kHz < 1,5 dB
Channel separation at 1 kHz > 24 dB
Channel separation at 15 kHz >15 dB
Frequency range at - 3dB 20-30.000 Hz
Frequency response FIM distortion at recommended 20-20.000 Hz + 4 / - 1 dB
Tracking ability at 315Hz at recommended tracking force *) > 70 µm
Compliance, dynamic, lateral 13 µm/mN
Stylus type Nude Fine Line
Stylus tip radius r/R 8/40 µm
Tracking force range 1,8-2,2 g (18-22 mN)
Tracking force, recommended 2 g (20 mN)
Tracking angle 20°
Internal impedance, DC resistance 100 Ohm
Recommended load impedance 47 kOhm / < 500 pF
Cartridge body material Noryl
Cartridge colour Black
Cartridge weight 4,1 g
