Greetings! I'm currently using GE 6SN7GTB's from the early '70s in the front end of my Red Iron Amps line stage. I really like them, but the bass seems soft. 'Any suggestions for other 6SN7's? Thanks...
While tubes do sound different, just because a tube produces "better" bass when used in one amp or preamp doesn't necessarily mean it will have the same effect in a different one. Differences in circuits play a bigger role, as do differences in the rest of the system . . . sources, speakers, rooms as well as an individual's hearing. Too many variables.
Audiophiles frequently have boxes full of expensive "holy grail" tubes which failed to produce the desired sound and now they're gathering dust. They were purchased because someone claimed they had a certain effect on the tonality (or some other aspect) of their system.
So was the person who made the recommendation lying about the tubes? Absolutely not. They really did affect their system as described. The key words being "
their system", not yours. So, unless someone has the same system as you, or at minimum this same preamp, their suggestions will be a total crap $hoot.
The most reliable way to alter the tonal characteristics of a particular system is to use EQ. If the issue is limited, a parametric EQ would work well.
Now if you can do without EQ, that's great. But the aversion that many people have to EQ is somewhat ridiculous considering that everything you listen to has been EQ'd (often extensively) during both the recording and mastering process.
I would also suggest that "soft" bass is often more related to the circuit itself - operating points in general and, specifically, the amount and implementation of negative feedback in either the preamp, the amp, or both. What kind of amp and speakers are you using?
If you post a schematic of your preamp, some of the more technically astute here might be able to offer a suggestion that will actually work and cost only a couple of bucks.
