Susurus
Resolution:6.62×10^-34
"Midrange is where the Music is". True or false?
Favorite midrange? DIY?
Worst midrange in a system-- non-tower AMTs?
I've kinda given up on 2-ways.
Integration problems in the critical listening band-- midrange -- where the ear is most sensitive -- seems best handled by a driver specifically for this. (unless you go planar...Maggies)
What I've got with incredible dedicated midrage: DQ-10, 12, 20, DQM-9, 9c, Bozak Symphonies.
Will be testing another 4-way tonight for midrange worthyness: HPM-series.
After some experimenting I'm convinced that a truly great midrange must have as a foundation a smooth, lifelike, well-integrated midbass.
For DQ-10s, his means close conformity to the original T-S parameters of the original (Advent-based woofer with improved VC).
However, I have not seen these specs. If I had the equipment I'd calculate them.
The tension between trying to achieve IT ALL:
full-range-ness,
best-integration-between-drivers,
and dynamics
...theoretically should be easier today than the vintage era. Better materials, tests, and QC?
- Susurus
full-range-ness,
and dynamics
- Susurus
