I have the VTF-15H MK2 in my second system- with the home theater. I tried it with the stereo system and it did not integrate acoustically as well with the electrostats.There is a HSU VTF-3 MK3 on Craig's List local to me for $350, I may look at that, it seems like a good deal.
I am getting close to deciding which way to go, I think the best way is to buy one great sub and buy a second of the same model when I can afford it. I'm looking at these subs:
1. Klipsch SPL-150, $795
2. HSU VTF-15H MK2, $970
3. SVS PB-2000 Pro, $900
I am leaning towards the HSU VTF-15H MK2 right now, but with shipping it's $1,152.
If you're going with SVS, I'd think about the SB, version over the PB one. Other folks will maybe have other things to say about it, but it seems to me that ported subwoofers, which offer a bit deeper bass are generally more prized for home theater as they can do more convincing special effects sounds (like in the sci-fi action move where a planet is splitting part and there's a big sonic boom). With the non ported version of that speaker, you do sacrifice a bit of bass (though not that much) but the quality of the bass that it has is a bit tighter and more musical. I think that with the non-ported too, you have a bit more options as far as placement because with a ported one, if you have it too close to a wall, the port of going to throw all of that bass to the wall and it's going to sound muddy... You might just prefer the deeper, somewhat less precise bass of the ported style, but it is something to think about.There is a HSU VTF-3 MK3 on Craig's List local to me for $350, I may look at that, it seems like a good deal.
Don't get me wrong it's a great sub, but even Hsu says that the ULS 15 II is better for stereo systems.
Subwoofers Comparison (hsuresearch.com)
You can plug the ports with the bungs and use it in sealed mode or without in ported mode or one in one out to tune as you please.That comparison is very interesting, I thought that with the plugs, I could make it a sealed speaker. Reading all of the sealed vs. ported, it sounds like I will like the ported sound better. Maybe I will send HSU an email and see what they think.
The Dayton DIY speaker route is interesting too, but I don't want to do that right now. Thanks for all of the input so far. I'm learning a lot along the way.
Dual RSL Speedwoofers. They pretty much have the best specs in their price range, or at least that's what I gathered from some site that had a HUGE database on a ton of different subs.So, if I were to go with 2 smaller subs, what does that mean? Can I do to smaller ones for $1,000? If I go with 2 SVS 12" SB-1000 I see they have two choices, both Pro models and they seem identical, sealed for $500 and ported for $600. What are the pros and cons of ported vs. sealed?
CongratulationsSo after getting a reply to an email sent to HSU, I pulled the trigger on an VTF-15H MK2. I sent them my original post and they replied: "I think the 15H MK2 with both ports open, EQ2, Q 0.3 should be great. Send a detailed room layout and we will suggest sub placement. That can make a huge difference too. The 15 H is extremely close to the ULS in musicality." So I have it on order and they show delivery this Friday. I'll see if one sub is enough for me. If not, I can save my pennies and get a second one at some point. I can't wait. Thanks for the input, I'll soon know if I chose wisely or not and at $969, I came in under budget.
Congratulations
Audiofreak71
Well I could give you some advice on gear for streaming but that may be another thread however, what I can recommend for a streaming service is Qobuz and if you can swing it get Roon to tie all your services together ie. Qobuz, Tidal , your Hard Drives etc.Thanks, I am paying the price for trying going cheap. Hopefully this will complete my system. The only variable left is the computer, since I play everything via Itunes. I need to find out if a better computer or sound card can make much of a difference. I also want to subscribe to one of the Hi-res music streamers, I want to be able to keep whatever I download during my subscription.
Audiofreak71
I need to do some reading in the Digital Sources sub-forum. I will check out Qobuz, Roon and all of the other options. Thanks!
Just remember one thing. 99% of audiophile complaints about powered subs are because the level is to high and/or the crossover frequency is too high. Frequently it's both.
If you can hear a subwoofer working it's not properly adjusted. The only time you should notice it is when it's turned off. The absence of deep bass is immediately obvious. That's why many use measurements to adjust and set a subwoofer.
Final thought: A properly adjusted subwoofer does not need to have the settings changed when going from movies to music. A flat extended low end is the same for both.
I would never put speakers on top of subs, unless they were hooked or bolted together in some way as the cabinet of the upper speaker will vibrate.
Thanks for that input, I did notice that playing with the volume once I "heard the sub" it didn't sound as good. I know there is no universal setting for the crossover frequency, but is there a rule of thumb for the starting point?
