Actually, I don't own any SACDs so DSD is irrelevant. My concern is only with the audio from DVD and BD movie discs. Ideally, the audio from the Oppo's HDMI audio output could be decoded by this presumably better DAC
Fusion 8D - Nuprime-X Also, because as the Fusion 8D would be USB connected and interfaced with JRiver the stereo/mono digital audio from the Oppo would be processed by DIRAC software or what other means I choose to EQ the room/system.
But no straight multichannel DACs I could find have HDMI inputs, but this one which is priced higher than I like and has features which I don't need very much.
exaSound Audio Design > Products > s88 Streaming DAC
So, I emailed Nuprime support to ask if this decoder
H16-AES - Nuprime-X would work with the Fusion 8D DAC to decode DVD/BD audio from the Oppo. No reply so far.
Worst case, though no system/room correction is possible, at least I could probably use the Oppo's stereo analog outputs, as long as I won't have to use the Oppo settings very often for syncing the audio with the video, as Bill Ferris said above. And this way at least I'll finally get some use out of the Don Sachs preamp that I bought last year to drive my First Watt F4 amp.
