JeffBuerster
Would it hurt my mc2105 to bi wire to my speakers? I was told it may improve my overall sound quality...
Jeff
Jeff
Kool. I was told to find a Mac guy and ask before I possibly damage my old amp which I love dearly. Thank you for your reply....No, not at all. Bi-wiring doesn't change the impedance or anything like that and it may make an improvement in the sound. I have some bi-wireable speakers that I made bi-wires for and with an a/b test, I felt like the one with the bi-wire sounded a bit better, if only subtilely so. Apparently some speakers benefit more than others for the treatment, but it can't hurt to try it with whatever you have...
Yeah thanks I did know this...You may already know this, but in case you don't... you HAVE TO remove the jumpers connecting the the 4 posts on the back of each speaker before you hook the amp up in bi-wire configuration or you will risk damage to your 2105. (great amp btw)
With the one pair of speakers that I have hooked up that way my A/B test showed a very subtle improvement with the bi-wire. Very subtle is the word, but I still figured, why not?Some speakers do OK with biwiring some do not. it just depends. With the speakers I have, that can be biwired, it did nothing to change the sound.
Yeah I have no plans on replacing my 2105. I was just trying to improve my sound to my polk and I heard that bi wiring MIGHT do a little..... Thanks for ur comment. JeffThe only advantage to bi-wiring is you are reducing the over all source impedance to the speakers by using a total larger gauge of wire reducing line loss. If you want to really improve your sound and don't mind giving up the meters, you want a MC 7100 or MC 754. Then you will really hear and improvement with larger wire. If you want meters, then I guess a MC 7200. All three have much lower distortion and better signal to noise with a higher damping factor and they all have Power Guard to protect your precious drivers. If they are 4 ohm you will get much more power from the 7100 and 7200.
True dat! ThanxDo it ...
It's easy and easily reversible ...
And easy to compare ..
Bi-wire one speaker and not the other ... then flip the balance button back and forth ..
Peter gave a good description of why it might sound better..
Doesn't hurt to exercise that usually untouched balance button either ..
What I see from the article, points to a simpler explanation than IM distortion, IMHO. The difference between a single cable vs. the bi-wire cables shows only that the dividing point of the crossover which is internal to the speaker box with a single cable, moves to the amplifier terminals in the bi-wired cable. It would seem to me that if one placed the current probe in the tweeter crossover circuit inside the speaker box you would see the same effect with a single cable.In the linked article, it was concluded and "proved by measurement" that there are some technical benefits that may or may not apply to your situation. Interesting read, if you are into details.
https://www.qacoustics.co.uk/blog/2016/06/08/bi-wiring-speakers-exploration-benefits/
I find that my Vandersteens seem to respond nicely to bi wiring.
They seem more dynamic bi wired but I do not have actual measurements to support what I think I hear.
