I reconditioned two of the 940s, a BIC 960 and a Zenith Allegro which was a clone of the 960 with a strobe added. (I got all 4 for free from a guy whose grandad had had a bunch of nonworking stuff around) All of them had hardened grease and all worked great after cleaning and relubing. It's probably not kosher but I was able to use WD-40 to unfreeze the works, then cleaned it off with rubbing alcohol and relubed with lithium grease. After the platter is off turn the turntable over and take off the bottom cover. Pay particular attention to cleaning the return mechanism that's visible on the bottom. The motors on these tables seem really robust, and when they work, for all the plastic parts, the sound is very nice and clean.
Penetrating oil will frequently NOT work for removing a BIC 940/960/980 platter, where the original grease has turned into glue.
Remove the spindle and plastic retaining ring. Then, using a soldering gun, or high wattage soldering iron, place the soldering tip right on top of the hole where the spindle goes and leave it there for as long as a minute. While this is going on, have a second person pry carefully upward on opposite sides of the platter using two flat-bladed screwdrivers.
Do not try to shortcut this procedure by using a heat gun. You will kill the rubber mat.
Once the platter is off, remove gummy grease from both the bushing & shaft and the thrust bearings. Relube the thrust bearings with grease and the bushing & shaft with heavy machine oil.
Best,
Fred
Best,
Fred
