SpeakerdeJon
Hi,
I recently found a BIC T-1 in good condition for $10 on ebay. The only problem preventing it to play was that it the recording switch was stuck in REC mode preventing play back.
After this fix I found that the flutter and wow is pretty nasty and I suspect that the felt has lost its elasticity contributing to uneven play back speed, everything else seems to work.
I have done some research and these decks are apparently a pain to swap out the belts in. I was going to change the main belt as it looks to be the easiest and in my mind has the greatest influence on playback.
If anyone has any ideas or advice on if I have the right idea let me know. Also I cant find the service manual on the net , if anyone can point me in the right direction that would be appreciated.
Regards,
John
Regards,
John
