Refurbing a Wega V4810 (TA-5650), have done all the caps on the power amp card plus the big smoothing caps. Also canged the values acc. to the service manual update. Strangely enough all components except the 4,3k resistors had the updated values and seemed to be original components. Even the resistor on regulator board was the right value.
Should I keep the 4,3k or change them back to the old value, 2,2k?
The bias was set to about 35 mV, instead of the higher 50 mV in the service manual.
How will that affect the sound?
It runs cooler but what abut the distorsion?
What worries me more is that it seems to be sensitive to radio signals. When the lid is off there is a noise like a mobile phone receives a call. When I put the lid on it disappears, but a faint high freq sound is still present. Seems it has smth to do with the volume control or in tis vicinity. Even if I move my hand closer to the pot, the noise decreases. Earth contact also improves.
Is it sensitive to Wi-FI signals? No mobile in the room. First I get this with a vintage amp.
Cheers
