The idea with the heatsink grease is to eliminate the air gap between the transistor and the mica insulator, and between the mica insulator and the heatsink (air is a piss-poor conductor of heat). To accomplish this, only a thin coat of the grease is necessary, as the grease itself isn't such a great conductor either (but it beats an air gap). Too much grease is as bad, or worse, than no grease at all.
Sil-pad is short for silicone pad. They are available from many sources, and vary considerably in their ability to conduct heat. The only ones I use (when I use them, which is rarely because of cost...they are terribly expensive [$2.30 each]) are K-10 pads made by Bergquist: http://www.bergquistcompany.com/tm_sil_pad_detail.cfm?oid=104264
The other problem with the Sil-pads are that, once they are used (compressed), they must be replaced if the part is later removed. Mica insulators are cheap, reusable, and as long as they are nice and thin, adding a thin coat of heatsink grease makes for pretty decent setup (I buy them by the 100 lot, and pick the thin ones to use. For the ones I deem too thick, I either use an X-Acto knife to 'split' them into something usable, or just toss them out).
Sil-Pad K10® is a thermally conductive Kapton composite film coated with
boron nitride filled polyester resin, offering the highest thermal properties of
the Kapton insulators with minimum thickness and lower thermal resistance.
Designed to replace brittle ceramic insulators. (Electrically Insulating Material)
