Thanks for the thread Glenn!
I have a question about measuring diodes in series. Specifically, 1N4148 in series to replace VD1212 diodes. When I measure a single 1N4148, no problem. But when in series, I can only get a measurement on the leads for each single diode. When I try to measure across both, I get "OL". Since the measurement for each diode is good, I know something else is up. Can you explain?
Thanks!
Thanks. Short of doing that to be 100% sure, is it a safe assumption that if the mechanical/solder connection is solid, and each diode is measuring correctly . . . that the diodes in series are good to install?
