Hi,
I've bought a second hand vinyl set up piece by piece from ebay.
A Yamaha TT-300 turntable
Rotel RA8408X3 amplifier
A pair of Mission 760 monitors
I switched on and I have that common problem of the set-up not seeming to have much volume.
I can turn it up full and it gives me a plesent but low key level, when you would expect it to be blasting out!
So, I thought does the amp have a phono sound stage? Well it's got a dedicated phono input but i know that sometimes this does not mean that is has the internals. The turntable has phono plug outputs and a ground wire which I've connected to the terminal on the amp.
I bought a little phono pre-amp (AV-link) as I thought this might be it, and hooked it up, and all I get now is a pulsing buzzing.
i've tried it with another amplifier which i know works, ive tried the speakers elsewhere so they're both fine. I'm not sure if a cartrage change would make any difference (to moving magnet?) but in turms of pick-up it seems to be fine. I feel sure there is a simple and common explanation but I am in the dark.
What do i need to do to get this set up working as it should?
Any thoughts?
Any thoughts?
