I mounted my pair up to my Altec 511B horns, re-capped Eminence 18db high pass, 12 db low-pass 800hz crossovers, and Altec 515-8LF woofers, these sound excellent, I need to tweak the Lpad as these seem more efficient than the Altec 902's. These really sound sweet, I'm so glad I bought a pair. Some pics attached for comparison, these little drivers sure pack a punch, the treble is so nice I unhooked my super tweeters, yes!!! I think they will also sound great on 811B horns in the Model 19's, Zilch, thanks for the suggestion on these drivers, Dave. :thmbsp:
Cute little buggers, aren't they?
Heads UP, guys and gals, get the requisite Faston connectors at the hardware store when you buy the 5mm screws if you don't have them, 1/4", I believe. If you get the terminals too hot soldering to them directly, you'll soften or melt their mechanical mounting to the diaphragm rear loading cap.
Yes, they're substantially more efficient than the vintage Altec drivers, and thus require L-Pads, fixed or variable, to balance with most low frequency systems. Find those 30923s, Dave, or build new ones, to provide the requisite passive CD compensation, adjusting R-2 for the flattest response. They'll play flat and smooth out to nearly 20 kHz without tweeters.
It's the Mylar diaphragms making the sweetness and detail, largely, I believe. Model 19 crossovers will provide adjustable compensation, albeit at their higher crossover frequency. You may have to add a supplemental L-Pad to them, as well, to lower the sensitivity into the "Optimum" range.
500 Hz is pushing their lower limits, but they'll certainly do 800 Hz on 511 horns. Several members have now confirmed the assessment that 811s are best used above 1 kHz, independent of the driver. 4552nd works nicely on those at Model 19's 1.2 kHz.... :thmbsp:
Note: Could a Moderator please move this discussion subsequent to the arrival of the drivers @ #33 over into a new thread the Speakers Forum? With so many members soon working with them, I suspect there'll be considerable interest in these application details and everyone's comparative experiences.... :yes:
