Heh, heh....I'm pumped!! Dave. :yes:
...Note: Could a Moderator please move this discussion subsequent to the arrival of the drivers @ #33 over into a new thread the Speakers Forum? With so many members soon working with them, I suspect there'll be considerable interest in these application details and everyone's comparative experiences.... :yes:
We PROMISE....Be good, now!![]()
Heh, heh....
And RTA moves up in priority at WojoLab....![]()
I like them because every side including the top and bottoms are finished in oak, they were built by a sound guy in Iowa for 515B woofers and 902-16 horn drivers. :yes:Mmm, those oak cabs sure are purty. :thmbsp: Don't feel bad, at least you can look at yours, & caress them, &...![]()
Well got the bolts last night and got them installed this morning. Put them in my 19's. As mentioned before had to turn the L-pads way down. It will be interesting to see where others have to set theirs. Just initial listen testing I put the MF just above Min and the HF to about 9 o'clock.
May need some more tweaking, but pretty favorable. Much better HF extension. Long term listening will tell if they have the "Ice Pick" affect.
Zilch: You mention adding an additional L-pad on the model 19... Can you elaborate?
Yes, because of the increased sensitivity of the BMS over the Altec drivers, you should pad them down in order for the M19 crossover to operate in the range of the "Optimum" settings on the controls. Where you are running them, i.e., with the HF at 9:00, confirms this. HF should be nearly full on to use the M19 compensation to its best advantage.Zilch: You mention adding an additional L-pad on the model 19... Can you elaborate?
The same approach would be applicable here, i.e., an additional fixed L-pad to move the adjustable one up into its "Normal" operation range above 12:00.I'm using that upgraded, single Lpad Eminence at 800hz, it's down to 9 O'clock and I might still lower it, efficient little buggers!!
Home Depot had the correct bolts, 5mm x 16mm, the 5mm x 20mm were too long. I lowered the Lpads to the 9:30 position and they seem to be blending very well with the woofers now, it's weird for me to be able to hear all that treble with the Lpads that low, I'm pumped!! Dave. :yes:
so I'm on a mission to aquire said bolts this afternoon.You're welcome, everyone should have their drivers by now, I hate to admit it but I'm already dreaming about getting more of these drivers for my other 3 pairs of A7's, pretty weird aye?? :sigh:Thanx for posting the correct size bolts, saves me some time, I'm sure. :thmbsp: I picked up some lugs & other things yesterday, & the drivers just got here a bit ago,so I'm on a mission to aquire said bolts this afternoon.
Not at all weird....I hate to admit it but I'm already dreaming about getting more of these drivers for my other 3 pairs of A7's, pretty weird aye??
Might be time for dual woofers?? :scratch2: Remember, the 511b horns are even louder!!Listened to mine all day yesterday, not fatiguing at all. Had to do some more fiddling with the L-pads. Right now I have them both near 8 oclock. Does't sound right with either one at full min, and still fell like there's too much top end, so will be playing with and additional L-pad and resistors.
http://audioheritage.org/vbulletin/showthread.php?p=128826&#post128826Listened to mine all day yesterday, not fatiguing at all. Had to do some more fiddling with the L-pads. Right now I have them both near 8 oclock. Does't sound right with either one at full min, and still fell like there's too much top end, so will be playing with and additional L-pad and resistors.
