Alright, so at around 80-90v on the variac, I'm getting a 4-5 amp draw. DC offset is around flirting around 0v most of the time. Never got higher than -0.1mV
"If the amplifier does draw a lot of current, that would point to a short or leak on the negative half."
So this appears to be the case now...The output transistors are getting warm as is the heatsink. Between 70-80 volts on the variac the current draw goes from .9A to 2.5A...
I found this bit in the service manual:
Removed the screws on Q9 and the high current draw disappeared. DC offset is at -44VDC. Op-amp output is 4.3VDC
Installed the Q9 screws, removed Q11 screws. The current draw was still present but shift until 2.5amp @ 95-100v on the variac.
Q11 driving the negative side output transistors. Disabling its collector disables all output transistors. So reconnecting it and going disabling individual output transistors one at a time in hopes of finding the offender...
Installed the Q11 screws, removed Q23 screws. No current draw issues. DC offset is at -63.3VDC. Op-amp output is 5.5 VDC.
Installed the Q23 screws, removed Q21 screws. No current draw issues. DC offset is at -63.3 VDC. Op-amp output is at 5.5 VDC.
Installed the Q21 screws, removed Q22 screws. Current draw 2-3 amps at 80V on the variac. DC offset -0.01mV.
Installed the Q22 screws, removed Q19 screws. Current draw 2-3 amps at 80V on the variac. DC offset -0.01mV.
Installed the Q19 screws, removed Q20 screws. No current draw issues. DC offset is at -63.3 VDC. Op-amp output is at 5.5 VDC.
Installed the Q20 screws, removed Q18 screws. Current draw 2-3 amps at 80V on the variac. DC offset -0.01mV.
So the current draw occurs when the negative side output transistors are enabled. When they are disabled there is a high negative DC offset. How is negative DC getting to the output line? Could one of the outputs be leaky?
In short:
With everything connected up as normal, we have large current draws before even hitting 100V mains power. Offset is within normal range. If I disable the negative side output transistors starting with Q9, the current draw vanishes and a negative offset at the output terminals appears.
