IsakAlexande
The room is around 38m2 or 400ft2.
You did ground the copper foil? Changing all the resistors for higher spec ones a waste of time and money or will the overall sound change too much? I`m getting a second one so I can compare a modded one to the original directly.
2857609 is a Rola code indicating they were made during the 9th week of 1976.
That's the pro version... using the same drivers as the 901 Series 1 and Series 2, except 4 ohms instead of 8 ohms (the 901 used 8 ohm drivers in those early model units).
The pro EQ (for the 800) had a slightly different EQ curve... less bass boost than the home version, and a LF cut-off filter to protect the drivers in a high-output condition...
IIRC, they use 4 ohm drivers... wired in series-parallel to get back to 8 ohms...
Regards,
Gordon.
The 800 is one helluva good speaker, period. I will say the same about the 801, especially the earlier models which, though quite inefficient (needs lots of watts) are very very accurate and a superior loudspeaker WHEN USED IN AN APPROPRIATE LISTENING ENVIORNMENT with adequate associated equipment.
We "Bose Bash" mainly because most of their recent and current products are so grossly overpriced and their marketed sound quality bears so little relation to reality that they've almost become a joke. The company has put out some excellent product and continues to do so once one gets past their mass-marketed items. Hey, I'd love to have a Wave Radio but not for the asking price. My Cambridge Soundworks radio sounds as good and its retail asking price was 1/3 that of the Wave Radio.
