Bose 901 EQ light/power switch
atrelstad
So I’m wrapping up my restoration of a Bose 901 Series I Equalizer, new caps and resistors throughout, and something strange happened. The neon light hasn’t worked since I got it, and I’ve yet to deal with a replacement. But yesterday when I (thought I) was finished and put it all back together, I had no output. Turned out after an hour of testing that a wire had broken loose going to the power switch, no big deal.
The odd side effect was that without the connection, my neon works! Once it’s fixed, nothing. This also lead me to notice that my power switch isn’t actually working, and turning it off has no effect. The Eq is definitely on as flipping tape monitor on/off makes a huge difference, but... what’s the deal?
I admittedly am handier with a soldering iron than I am knowledgeable about what I’m actually doing, so maybe someone could clear this up. Should I just replace both my switch and bulb? I had a theory about the bulb getting more power because the rest of the circuit wasn’t getting it? Just about the only two things I haven’t replaced are the resistors in the switch, so maybe that’s something to do with it... I’m going to mess with it some more tonight but any insight would be appreciated.
Those switches usually have 3 connections. One is to illuminate the neon (it needs a neutral to make it work). The other is to pass current on (the real switching part). I suspect you have wired the switch wrong.
Here are before and after pictures, the top of the two wires was never removed so I definitely didn’t switch them. The bottom wire just broke so I reconnected it. Discovered the neon popped on while it was disconnected. As far as I can tell the board seemed untouched before me, but maybe they had it wrong from the factory? I’m also not sure if the power switch worked before this, without the neon it’s harder to tell and I never necessarily had it off, just unplugged.
Never figured this one out. My EQ works great, but the switch doesn't light up. I've seen it flicker once or twice, but nothing more than that. I suspect a new bulb might do it, will update here if I ever get around to it.
