I wonder what shape the protection relay contacts are in? :scratch2:
mmm don't know. Will have to check that. Are they prone to failure?
Today i received the large PSU CAN's from Mouser. The look similar to the originals and fit in the available space.
How did the relays make a world of difference to your B-2?
Digikey sells them (Vishay/BC Components NFR25/NFR25H), and on this unit I'd replace fusible resistors with the same, if at all possible.
Unless you have access to some very high-tech glue, using same for a metal-to-metal bond is never a good idea. If it pops loose (which it will do, given time) then could easily short your outputs and good-bye VFETs. Drilling the chassis and using nuts & bolts would be much more secure. Or rivets.
:scratch2: :beer:
I hope it is not the Vfets. Price was good so i decided to buy it.
