What you're seeing is that it actually has too much anti-skating applied, maybe because it is brand new and the anti-skating spring is still rather stiff. Try reducing the anti-skating dial setting until the tonearm no longer is pulled outwards.
Then set it as close to the middle point as you can achieve to get the tonearm to stay still when placed in the middle of a LaserDisc. (Remember that the amount of skating effect changes depending on the radius, but the anti-skating system only works at one level, so you need to set it to what works best in the middle of a record.)there is not any adjustment that will remove that pulling outwards without changing into pulling inward. At 1,5 (circa) the arm is pulled outward or inward until it more or less reaches the center of the record.
Not speaking for Vincei, but I follow Peter Ledermann's advice (that he got from Frank Schroeder) to use a wide space in the runout area and set anti-skate so that the arm moves slowly toward the spindle (until, of course, the groove wall catches up with the stylus and drives it quickly toward the spindle).Thanks for your feedback. How did you decide it’s double? What test did you do?
I believe you are confusing AT-LP120USB (from your picture) for LP120X. Which is what OP has, and his AS is in fact fully functional, maybe even too powerful. But this isn't an issue & can be easily adjusted. Just like on my AT-LP140XP, which is also what @56RETROGRADE said, it does seem to have too aggressive AS which needs to be corrected, slightly decreased. So, instead of 1.5 maybe go for 1.0 AS (assuming the tracking force is set to 1.5g), or 1.5 if the tracking force is 2.0g.Here is a fix I did to mine when I had it. Glued the red bead with hole in it to tone arm pivot frame, run some light fishing line tied to pivot (as shown) thru bead and then attached to fishing weight. Worked great. Set the AT's anti-skate to zero.
View attachment 1735964 View attachment 1735965 View attachment 1735966 View attachment 1735967
