As an architect living in Germany, there was no way i could avoid beying attracted by some Braun gear. I can honestly say that they are not only nice, but also nicely designed, with a few unexpected features.
So is the case of the Bran PS 430 turntable. It is the simpler brother of the PS 500. Both are a belt idler hybrid (the other way arrounf compared to the TD 124), almost identical and made mostly of metall. But they also have a few differences, the 500 has an oil damped chassis, while the 430 has a spring suspension (similar to, but much more sturdy than the TD 150).
After owning (for a short time) a td 150, and seeing the importance of damping, i thought why not try to apply the same principles to the Braun. The 430 has really hard springs, that make the chassis seemed almost glued to the top plate. You push it down, and it comes back almost instantly, while on the TD it bounces gently for a while.
My idea was to try and use Linn springs (430 chassis is massive and heavy), which should be more suitable, and try to see if it bounces, and see if it is an improvement or not. Other upgrades are also possible with a bit of diy (or a friend with a cnc which i do not have).
First step is to do a visual check of the suspension system of both decks, and see if this can be done with minor, and most importantly undo-able, mods.
Will be back with some side to side under the hood photos. Interesting to see the differences in ideology, manufacturing and complexity between the two.
