Thanks @Peter lye . That answers my question very nicely. I guess I should read through that 777 thread too.
Great score I’d replace the 2sc458 transistors they are known to fail and can cause damage to other components if they fail might even reduce some of that hissksc1815 is the substitute you need
if it looks original go with what Sansui fitted to your Sansui from factory, its always a good idea to go off what's in your unit when original rather than the schematic as there are often changes during production and schematics are rarely updatedMy Mouser order showed up! I think I'm going to start with the power supply. Already found one issue. I ordered parts off the parts list and didn't compare very well to the schematic and what's actually in my 555. So one of the resistors is a different value from what's in there now. I'll add the right one to my next order. It might be ok to leave the old one there for a little while. It's 1/2 watt instead of the 2 watt upgrade.
Thanks! That's what I plan to do. This probably isn't the last time I'll run into this issue so I'm just going to wait a bit to place my second parts order and hopefully get whatever I messed up on the first.if it looks original go with what Sansui fitted to your Sansui from factory, its always a good idea to go off what's in your unit when original rather than the schematic as there are often changes during production and schematics are rarely updated
I thought I had some lugs but the only ones I could find were automotive ones that wouldn't take solder very well so I did it the hard way without them. It turned out ok but I would have rather had some lugs. If you have a link or type you use, please share. I'll pick some up.Well done keep up the good work I use lugs which I solder to the snap in capacitors so it’s easier to mount wires.
I’d recommend replacing the 2sc458 transistors they are very unreliable and can cause damage to the amp next
I have some 1815s on the way and should have them in a few days. Thanks for that link.Just FYI @Brian1970 and as a follow-on to the 2SC458 discussion we had - I happened to come across this post (it's for a 350A) here KSC1845s caused issues when used for 2SC458, on the F-1248 tone control block.
https://audiokarma.org/forums/index.php?threads/sansui-350a-strange-clipping-problem.755929/
Changing to KSC1815s seemed to solve it.
I had some similar ones, but not molex branded. Pretty sure I got them from an auto parts store. Do these take solder well? Mine did not.
Just thought of a question I've been meaning to ask. Do any of the transistors in the 555 need to be matched? If I understand correctly, only differential pairs need to be matched. I don't think the 555 has any of those but I'm not positive about that.Just FYI @Brian1970 and as a follow-on to the 2SC458 discussion we had - I happened to come across this post (it's for a 350A) here KSC1845s caused issues when used for 2SC458, on the F-1248 tone control block.
Yeah they seemed to! Just got it hot enough and solder flowed all around and inside the crimp.Do these take solder well?
