david winter
Classical music lover.
Hi,
I need to replace the broken start switch of a Dynacord IST 104.
The original model is a Dialistat 2-pole type (DPDT), same as the one pictured below but with a larger metal holder allowing screwing it to a metal plate, itself attached to the metal body of the turntable.
The blue plastic axis broke: unless there is a reliable glue which can stick both parts by slightly melting the surfaces together (acetone does nothing), I must find an exact replacement due to the way it attaches to the chassis, otherwise I may not be able to use the same rectangular push-button passing through the body.
Anyone if these can be still found or whether there's an exact replacement ?
Thanks.
Thanks.
