JimmyEL34
The set up:
Power:
Two Bryston 7B3 monoblocks (600w @8ohms/900w @4ohms)
McIntosh MAC6700 200w @8/4/2ohms (using autoformers)
Pre-amp:
McIntosh MAC6700 pre-amp stage (output 1 fed to MAC6700 power amp stage, output 2 fed to Bryston 7B3 monoblocks)
Speakers:
Magnepan 3.7i
Turntable ensemble:
Technics SP10 MkII table & control box (rebuilt by PBN Audio)
PBN GrooveMaster plinth
Sorane ZA-12 12” tonearm
Denon DL103 cartridge (VTF@2.65g)
Phono stage:
MAC6700’s integrated MC phono stage set at 200ohms)
CD transport:
Tascam CD240
DAC:
MAC6700’s integrated DAC 32-bit/192kHz PCM/DSD
Method:
Speaker cable physically disconnected/connect from/to the McIntosh/Brystons for back and forth comparison of the same tracks
Why?
I love the sound of the Maggies with the Mac but noticed I had to turn the volume up around 53% (avg. ~70dB / peaks ~85dB) before they really sang. Things got better once the Maggies got passed the 6 month mark, but still, the Fletcher Munson curve was more pronounced than with cone speakers. I did a lot of forum reading that suggested, while inherently a characteristic of the Maggies, it could be somewhat remedied by using a high-powered/high-current amp, especially an OTL amp with a high dampening factor. Two amps kept reemerging again and again in the forums: Bryston and Pass Labs. (Mac amps with their autoformers (output transformers) were generally discounted as “not working well” or “would not be a good match” with planar type speakers. However, a few Mac owners would chime in saying they were using Macs with great success paired with their Magnepans.) My local dealer carries neither Bryston nor Pass, but then, I stumbled across a pair of 7 month old Bryston 7B3’s in new condition at a price I couldn’t pass up; even just to own them on a gamble of not liking them and having to re-sell them. So, here we are...
Key:
(7B3) = pair of Bryston 7B3 monoblocks
(Mac) = McIntosh MAC6700 integrated receiver's power stage
Music auditions: (This section was too long to post here - if you want to see the song reviews using these two amps, please read the music auditions)
<<< The Final Analysis >>>
Overall winner:
7B3
Most surprising:
How similar the 7B3 and Mac sound. While I've never heard a Bryston amp before, I had read that with the "3 cubed" series, it was designed to have a smoother overall sound profile compared to previous series. Except in very dense and complex recordings, to my ears, both amps had virtually the same sonic signature (or lack there of).
Most impressive:
How the 200 watt Mac was able to hold it's own against the 7B3's 900 watts - the 7B3 never "sounded louder". Depending on the recording, the 7B3's bass was stronger (you could feel it), dynamics, articulation, and soundstage were better and larger, but no perceived difference in loudness. In fact, I kept the pre-amp's volume control set at 53% for both amps and the perceived loudness was the same regardless of which power amp was being used.
Observed generalizations:
1) Pop/rock LP's pressed from a digital source, sounded warmer and more cohesive on the Mac.
2) Large ensembles, albums recorded in large venues, and complex/dense/fast music sounded better on the 7B3s - in fact, the more complex and dense the music, the more the 7B3s stepped up to the plate and really showed their magic...
3) Likewise, smaller ensembles and less complex music sounded better and more cohesive on the Mac.
4) All of my CD's sounded better with the 7B3 - most of my CD's sound fuller and warmer I assume because of the extra watts. I never liked how thin and flat my CD's sounded as amplified through the Mac - the 7B3 really brought them back to life, closer to an analog sound.
5) Most of time, the 7B3s produced more bass that was well articulated, fast, and great "chest feel". However, on certain recordings, it's almost like the 7B3s produced a "scooped" bass sound where the fundamental mid tone was recessed so that you were "feeling" the very low end and just hearing the high-end articulation of the note. Whereas, in these cases, the bass seemed louder and punchier on the Mac, but sans the "chest feel" and better articulation.
6) 7B3s have the uncanny ability to resolve the minute details of room acoustics - reverberation, decay, ambiance, vibe, etc. (see "Moonlight" review above).
Most perplexing:
I was expecting to hear huge differences in these two amps - especially regarding all the threads out there discussing how OTL amps are the best to use with Magnepan's and how the Mac's autoformers roll off the high-end and suppress detail, etc., not to mention the difference of 700 watts between the two.
Biggest disappointment:
After reading so many forum threads regarding the Bryston/Magnepan match being made in heaven and how the Bryston amps would really make the Magnepans "sing", I still had to keep the volume up at the same level I use as when they "sing" with the Mac. (Yes, the Magnepan's did "sing" better at the same volume with the 7B3's, but I guess I was expecting something more dramatic going from 200wpc to 900wpc, as well as the Fletcher Munson curve effect being reduced; alas, it wasn't.)
Biggest question:
For all the things that the 7B3s did better than the Mac (bass you could feel, better dynamics, more transient details, larger/taller soundstage, uncongested and accurate reproduction of large ensemble performances, impressive reproduction of recording venue ambiance, etc.) was I simply hearing the benefits of stepping up from 200 wpc to 900 wpc? Or, was there, in addition, something inherent to the Bryston that was contributing to these sonic improvements?
Next steps:
Now that I know what the 7B3s are cable of in my system, and to answer the above question, I will now be scheduling an audition at my local dealer to listen to the Mac MC462 and MC611's hooked up to the Magnepan 3.7i's. I will be grabbing the music I listed here and will be listening to hear if the higher powered Mac's can reproduce all the goodness I heard from the 7B3s.
...And beyond:
If the above audition reveals that the higher powered Macs can reproduce most of the goodness heard with the 7B3s, and at the same time, not reproduce the "shoutyness" or "glare", nor the anomaly of recessed vocals, on the same songs as tested with the 7B3s where those negatives appeared, then I will sell the 7B3s and look to upgrade within the Mac family. If not, then I'll keep the 7B3s and upgrade to a Mac tube-based pre-amp.
Stay tuned:
I'll update this review after I audition the higher powered Macs with my findings. (And if you made it through this too long review, thanks and cheers!)
Power:
Pre-amp:
Speakers:
Magnepan 3.7i
Turntable ensemble:
Phono stage:
CD transport:
Tascam CD240
DAC:
Method:
Why?
Key:
Overall winner:
7B3
Most surprising:
Most impressive:
Most perplexing:
Biggest question:
Next steps:
...And beyond:
Stay tuned:
