yeah I have seen some high end guy showing off his USA made stuff. He did put the transformers in series. Later on his amp went up in smoke and he did not understand why.WTF?
Just run the two transformer primary's in series for 230 volts?
Buck
So, if someone had brought in a 2B-LP you would have tested it to see that it could continuously produce 100WPC into 4 Ohms? How long is continuous? Rectification gains don't buy you anything in terms of secondary sag under load when the core is saturated.Remember depending on the type of power supply rectification and filtering the DC voltage can easily be 1.5 times higher than the AC voltage coming out of the power transformer.
As others have said Bryston is a well respected amplifier and easily meets it specs in RMS power from 20 to 20 KHZ with room to spare. When we had Mcintosh amplifier clinics as a dealer and when we had a few come into our shop that had been abused they always met specs over 90% of the time. The ones that didn't definitely been damaged. Exposed to liquids or power surges and voltage fluxuations from the power company. OLD Mexico at night the wall voltage could easily drop down to 90 or 95 volts while reaching over 135 volts at other times. Our side of the border stays between 122 to 127 volts as we are close to a power sub-station.
No. It's just based on math and design principles.
Get a pair of dummy loads, feed in a sine, drive the amp to rated spec, view the output on a decent 'scope and report back. Then you will know if your bodge transformers are up to the task or not.
Bryston amplifiers are probably one of THE most conservatively rated products on the planet. They rate to FTC spec with plenty of reserve. I've had only a few over the years and they delivered nearly 30% above their continuous rated power and THD ratings.
Like I said, it's my misunderstanding of the published spec. I thought 50@8, 100@4, 200@8 bridged, meant continuous for all of these... but it does not. It's only for the 50@8. That's a bit disappointing compared to my other amps which do have sufficient power supply to continuously deliver their 4 Ohm rated output.Hey, it's your amp. Personally I don't care if you connect it to external 1000VA transformers if that would trip your trigger.
The point is I don't believe the assertions the Bryston amp wouldn't meet or exceed published specs as designed. If it didn't that would be considered broken and they'd repair it under warranty... albeit the 20 year warranty is long past on your 1987 purchase.
